Wireless Modem
aa_452
Visitor
Difference in cat M1 and Cat 1 devices ?
Is CAT m1 devices work in areas where CAT 1 devices work.?
Is there any special antenna requirements for CATM1 devices ?
could you please answer above questions ASAP. We need to take decision to buy modems as per your feedback.
 Thanks and Regards
patoberli
Just to understand you correct, do you have two examples, one CatM1 and one Cat1?
I just found this here, maybe it already helps you: https://www.soracom.io/iot-definitions/what-is-cat-m1/
