wireless network disconnection
Nadia Bbz
Level 4
Level 4
Dear Team ,
i have problem with wireless network, connection is so so slow to access internet or local application , i  lose regularly connection to CISCO WLC or local application
the picture as attached depicts the issue
Thanks for help
14 Replies 14
ammahend
Do you still see the same issue when you connect the endpoint to a wired network ?
also share output for “show client detail mac_address_of_effected_client” from WLC
-hope this helps-
i haven't this issue with wired network
all connected wireless user have this issue , they get always disconnection to local application
Can you paste output for one of the connected client as asked before, also based on your response to Scott seems like this is a new issue which happened just today, are you aware of anything that changed recently?
-hope this helps-
hey @ammahend
you find as attached result of command
Thanks for the output, just curious where are you physically located, since your client is connected on channel 13
-hope this helps-
Scott Fella
Can you provide more info? You sure you don’t have a duplicate address issue or a misconfiguration? Is this a new setup or was this working fine and then started to fail?
-Scott
I haven't duplicate address IP , before all work fine, but today i get this issue  in wireless connection
Leo Laohoo
Aside from the two screenshots, what troubleshooting have been done?
hey @Leo Laohoo
the troubleshooting that i did
at the time of disconnection
wireless client : can't ping neither the  gateway of vlan wirelss nor le WLC or any other ip address
wired client : i can ping the gatway of vlan wireless and the controller
i get always disconnection in wireless network
Well, if the wireless client is disconnected from the WLAN, why would it be able to ping any IP address when it doesn't have an IP address?
Create an SSID with open authentication.  Make sure the SSID is using the same dynamic interface.  See if this problem occurs with an open SSID.
hey @Leo Laohoo ;
i have two SSID
one with 802.1x and other with web authentication , i get this issue  in both of them
Can you run a debug when this issue is occuring?
You still need to provide more info. Did anything change, since you said it worked before, is the issue with one or all devices including phones or different model laptops? Did you look at your radius logs?
-Scott
hey @Leo Laohoo ;
I don't know how to use this command debug, the picture below depicts that is disable which line should i enable them
