wireless not working login
TimMees60387
Level 2
Level 2
I have a problem with my Cisco wireless, the login is incorrect, does anyone know a solution?
8 Replies 8
Enes Simnica
hello @TimMees60387. If u're seeing an "incorrect login" error on ur Cisco wireless device, here are a few things to check:
  • Default Credentials: Try admin/admin or check if someone has changed them. Some models may not require a username.
  • Console Access: Use a console cable and terminal software (PuTTY) to connect directly. This is helpful if the GUI or SSH isn't working.
  • Password Recovery: Most Cisco devices allow recovery by interrupting the boot process. The steps depend on your model.
  • Factory Reset (last resort): If recovery fails and u're still locked out, a factory reset will wipe all settings, so make sure you have backups.
also check these links G:
hope it helps G
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Mark Elsen
@TimMees60387   - That is not enough info to proceed with, what is the cisco wireless component or components you are talking about ? Are you  talking about administrative access or user access ?
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
it's about cisco 892W after
  - @TimMees60387    Did you try the default credentials cisco/cisco as being mentioned on the login screen ?
  M.
not working tried several times
 - @TimMees60387   Check if these info's can help you : https://www.cisco.com/c/en/us/support/docs/routers/800-series-routers/12065-pswdrec-827.html
  M.
this for wireless module the password
   - @TimMees60387      Probably the only way to get out is to reset the wireless module
                             Try service-module wlan-ap 0 reset default-config
                                       and then reset the AP module
                                 You may then only need an enable password for connecting to it (getting privileged access)
                                 which is  Cisco
  M.
