No valid AP manager found for controller
Jegan Rajappa
Level 3
Level 3
Hi, After upgrade Cisco 5520 WLAN controller from 8.5.151.0 to 8.10.151.0, all Cisco 2802 APs couldn't join controller, however Cisco 2702 AP joins.
By looking into AP console, it says 'No valid AP manager found for controller'
It seems AP downloaded 8.10.151.0 code, but couldn't join controller
 - Tried to factory reset AP hardware, no luck.
 - Management interface has AP manager tick.
 - NTP looks good
 - Both WLAN controller and AP are in same broadcast domain
Does anyone have any advice?
10 Replies 10
Sandeep Choudhary
Can you check:
1. If RTU license is activated or not ?
2. If management IP and service port IP is on the same network or on diff . FYI: it must be on diff network
You can also try this command on one AP CLI : capwap ap erase all
Dont forget to rate helpful posts
Hi Sandeep, RTU is activated and has enough license
Mgmt and service port is in different network
tried capwap ap erase all, no luck, tried factory reset with mode button, no luck
The management and service port does not have connectivity between then... correct?  Take one of the 2802's and place that on the same vlan as the management interface and factory reset the ap using the mode button.  See if the ap joins or not and if you see the same message or a different message.
-Scott
Leo Laohoo
Post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. WLC:  sh ap join details <AP MAC ADDRESS>
  4. AP:  sh ip interface brief
  5. AP:  sh version
NOTE:  Do not post screenshots.  Copy-and-past or log the output to a text file and attach it to the response.
Jegan Rajappa
Level 3
Level 3
Worked with TAC and got bug ID, it seems there is no fix yet 😐
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy37953
@Jegan Rajappa wrote:
CSCvy37953
Thanks for the Bug ID.
Now for the pressing question:  Is this bug present in 8.10MR6?
Yes it is present and annoying... on vWLC 8.10.196.0, reboot and clear config AP did not solve it.
  -  @RxTx    Not helpful to revive old threads , poster and followers may no longer be involved with the issue ==> start a new thread and describe your problem from scratch.
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Can you paste the management VLAN configuration here if there's HSRP configured?
Jaccobbchoi
Frequent Visitor
Frequent Visitor
May I know if you pointed the gateway of the APs to the HSRP Standby IP address? If yes, can you paste the settings of your management VLAN configuration here?
