Wireless PEAP Authentication
murali.rao
Community Member
>We have a customer with ACS Version 3.3 authentication problem in Wireless.
>Whenever a user logs for first time "Username and Password" is prompted and the user is authenticated.
>For Subsequent logins, the "Username and Password" is not asking and the Client is directly getting authenticating and succeeded.
>Access Point is IOS Based with 12.2 Version.
cpinal
Frequent Visitor
Frequent Visitor
Hello!!!
Mauril I have the same problem about the prompt at first time all was ok but when i log second time prompt didn´t appear and directly detect that the a valid user i have to un check the option fast reconnect on ASC but nothing change
If you find the solution I will appreciate that you say me how you did to solve the problem
Some operating systems "remember" user credentials. Windows XP put this information into registry.
HKEY_CURRENT_USER\Software\Microsoft\EAPOL\UserEapInfo\
You can find more information in MS knowledge base, http://support.microsoft.com/default.aspx?scid=kb;en-us;823731
You can automate this procedure by putting the following information in file called i.e. delete-cache.reg and executing appropriate command.
-----cut-------
REGEDIT4
[-HKEY_CURRENT_USER\Software\Microsoft\Eapol\UserEapInfo]
-----cut-------
regedit /s delete-cache.reg
ROK
