Wireless PEAP Question
zhenningx
Level 8
Level 8
Has anyone used the XP PEAP client authentication option "connect to these servers"? What is the use of that option? The windows help about that says if you only want to connect to certain servers for example microsoft.com, type microsoft.com. I typied cisco.com there, but my client still can connect to the servers in my domain.
a.kiprawih
Level 11
Level 11
I think that option is not to restrict access to certain websites, but more towards limiting or specify which CA server automatically used to identify the client.
http://rorschach.concordia.ca/neg/remote_access/wireless/general_info/peap.html
http://technet2.microsoft.com/WindowsServer/en/Library/ecb5c750-9917-48eb-b33b-8404a57e396b1033.mspx?mfr=true
Hope this helps.
Rgds,
AK
Thank you for your reply.
I did not mean restricting access to centain websites. I typed "cisco.com" in that field, but my client still can be successfully authenticated by my ACS server in my domain. I used the same way to configure as the concordia univ doc. What is the reason for that?
