Wireless Ping/Link Test
bm_5789
Level 5
Level 5
I have a cisco wireless client associated and authenticated to a cisco 1200 AP. In the AP's GUI interface, I perform the Ping/Link test. The ping test results are 100% success. When I do the link test, the Link Test Output reports "No response from xxxx.xxxx.xxxx. Any ideas on what is happening with the link test? Thanks in advance for any help/advice.
smahbub
Level 11
Level 11
If you have enabled any security features like EAP try disabling them. Also are you able to ping networks beyond the peer AP.
We are using LEAP...so you recommend disabling it for the link test?
Not sure I understand your second ?
