wireless Qos config at switch
Leftz
Level 4
Level 4
Hi we have wireless 9800 system. APs are connected to C9300 switch. The client would need some meeting via MS Team etc at their PC or laptop. In the configuration of switch port connected AP, we have several choices as below. Which one is better for the purpose? Thanks
SW(config-if)#auto qos ?
classify Configure classification for untrusted devices
trust Trust the DSCP/CoS marking
video Configure AutoQoS for video devices
voip Configure AutoQoS for VoIP
balaji.bandi
check how the QOS can be configured :
https://mrncciew.com/2013/07/23/qos-for-h-reap/
BB
balaji.bandi
BB
Leftz
Level 4
Level 4
Thank you balaji for your reply. its a good article. I know the author published a lot ones
Can I ask one more question in this thread? it depends on what kind of mark would be added in WLC. so it depends on the configuration at wlc. can you comment on the configuration at wlc?
If you looking to implment on  Cat 9800, look same Blogger have good information :
https://mrncciew.com/2021/10/06/9800-auto-qos/
BB
