Wireless re-authenticating randomly
TOM FRANCHINA
Level 3
Level 3
I have been working on this issue for several weeks. Now I have found the issue in Prime when I logged the client. But I am not sure how to solve the problem. The PC never moves from the desk... so I don't know why there was a Controller change, loss of DHCP and a re-auth. Here is the log:
Time :2017-May-17, 14:56:27 EST Severity :INFO Controller ID :10.10.99.251 Message :Mobility role changed. from Local to Handoff Peer = 0.0.0.0, Old Anchor = 10.10.99.251, New Anchor = 0.0.0.0
Time :2017-May-17, 14:56:27 EST Severity :INFO Controller ID :10.10.99.251 Message :DHCP Failed.
Time :2017-May-17, 14:56:28 EST Severity :INFO Controller ID :10.10.99.251 Message :Received DHCP request, client is in invalid state.
Time :2017-May-17, 14:56:32 EST Severity :INFO Controller ID :10.10.99.251 Message :Received DHCP request, client is in invalid state.
Time :2017-May-17, 14:56:40 EST Severity :INFO Controller ID :10.10.99.251 Message :Received DHCP request, client is in invalid state.
Time :2017-May-17, 14:56:56 EST Severity :INFO Controller ID :10.10.99.251 Message :Received DHCP request, client is in invalid state.
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, VO:0, VI:0, BE:1, BK:0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, VO:0:0, VI:0:0, BE:0:0, BK:0:0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, 46
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, 53, 0, 0, 0, 0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, VO_INNER_DSCP:0, SIG_INNER_DSCP:0, BE_INNER_DSCP:1, OTHER_INNER_DSCP:0,VO_OUTER_DSCP:0, SIG_OUTER_DSCP:0, BE_OUTER_DSCP:1, OTHER_OUTER_DSCP:0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message : 88:90:8d:67:bb:a8, 1, VO_INNER_DSCP:0, SIG_INNER_DSCP:0, BE_INNER_DSCP:0, OTHER_INNER_DSCP:0,VO_OUTER_DSCP:0, SIG_OUTER_DSCP:0, BE_OUTER_DSCP:0, OTHER_OUTER_DSCP:0
Time :2017-May-17, 15:02:55 EST Severity :INFO Controller ID :10.10.99.246 Message :Active calls on ''{0}, radio {1}'': {2} 88:90:8d:67:bb:a8, 1, 0
Tom
Leo Laohoo
Sleeping Clients?
Leo
No the PC is plugged in and I see it live. Set to never power anything off.
did any AP failed close to the client ?
what the idle timeout and session timeout set, do you see any correlation ?
whats the dhcp lease time, do you see any correlation with dhcp half time ?
is the issue only on this client or multiple clients ?
-hope this helps-
We made changes to the idle time and session time. That did help. But we are still getting one re-auth during the day. We run 24/7 in a hospital and trying minimize any disruptions.
DHCP is 6 month lease and it happens to most all the wireless devices that require authentication  public wireless never has an issue
