Wireless Regulatory Domian in Argentina
m.milano
Regulatory Domian in Argentina is A.  My cuestión is IT a can use an AIR-CAP2702-B-K9 un my country.
Thanks and Regards
 You can. But, you need to configure your WLC accondingly.  A and B was used by US Country until recently. Then, US started using B and a few Countries in Latin America is using A.
  In order to make the AP join the WLC, you need to go to the Wireless Tab, under Country, select US and Argentina.
  Just keep in mind that you should run AP A to avoid any problem with local regulators.
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
