Wireless repeater mode
murmucka
Level 2
Level 2
aironet 2702 AP (autonomous mode) is it possible to use it as wireless repeater for all wireless networks, or only the compatible cisco root wlan's?
I have a 9120axe with EWC configured and i want to use 2702 as wireless repeater. Thanks for any help.
balaji.bandi
I do not believe that a workable solution with 2702 Ap a repeater.
BB
 What you can try is use the AP in bridge mode. Brdge mode is similar to a repeater. But, in brigde mode, the AP joins the WLC through another AP, consequently, you are extending your network.
Rasika Nayanajith
You can configure 2702 in WGB (Workgroup bridge mode) & get it connected to your EWC AP. Though I have not tested it by meself with Ligthweigth AP as root, you can use the below post to get an idea of how WGB needs to configure
https://mrncciew.com/2014/01/04/wireless-wired-clients-behind-wgb/
Rasika
*** Pls rate all useful responses ***
