Wireless Security Issue
Scott Fella
I have a client that has a WAN with both 340 and 350's. The problem is, the wireless cards they have are not WEP enabled. Is there a way to still have a secured WLAN, maybe a third party software or device. They run IP, IPX, and Appletalk.
-Scott
aonibala
Level 3
Level 3
Use IPSec.
blue.modal
Level 6
Level 6
If they can afford it, you can use Citrix for both on-time certificates and to radically improve performance over the WLAN.
