Wireless Security
Hello All,
I successfully integrated Cisco WLC with Microsoft NPS. When we applied group policy, user PC successfully connects on reboot but says "action required" once the PC hibernates.
The client PC should connect seamlessly both on reboot and after it hibernates.
Any help please will be appreciated
patoberli
And what is the action you have to do?
Also make sure to use current wireless drivers on the clients, for example Intel fixed various Standby issues in the last few months in their drivers.
Grendizer
Disable Fast Connect option for EAP in NPS
