Wireless Setup Issue
jfrye5445
Community Member
Hi all.
We have just swapped ISP's for our business and no longer have DCHP. So I have to manually configure every machine we have throught the building. Now I have a Aironet 1200 connected throught the switch that cannot be setup due to the fact that anyone that tries to connect to it can only see it. They would have to know the available IP, DNS, and gateway to connect.
I have a Cisco 2651 router available that we just disconnected, due to the fact that they installed a 1700 series router.
Is there anyway to integrate the old router with the new one in order to place the wireless in a secure environment as well as provide public access to our customers?
Thanks for any help
chris.houston
Community Member
Why not use the old router to do DHCP (Assuming you control the router)? That may be the quick easy fix. Here is a sample config. Hope this helps.
ip dhcp pool DHCPPOOL
network 10.0.0.0 255.255.255.0
domain-name
dns-server
default-router 10.0.0.1
netbios-name-server
lease 7 (number of days)
! range to exclude below
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp excluded-address 10.0.0.250 10.0.0.255
