Wireless Signal interference.
EmekaJay
Community Member
Are APs operating on UNII-2 channels required to use Dynamic Frequency Selection (DFS) to avoid interfering with radar signals.
Rich R
Regulations vary by country so you need to refer your own country's regulations.
https://en.wikipedia.org/wiki/Dynamic_frequency_selection
Cisco WLCs configured with the correct country code and AP model (you must buy the right model number for your regulatory domain) automatically apply the regulations for the relevant jurisdiction.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Haydn Andrews
USA/ Canada/ Australia/ EU to name a few all require DFS for UNII2 and UNII2 Extended Channels.
What channels and power levels / If you can use indoor/outdoors are all defined by each countries regulatory body.
As @Rich R said as long as the WLC country code configured correctly and the correct AP model for the regulatory domain are used then the WLC will ensure you don't breach the rules (unless you happen to place an indoor model AP outdoors)
*****Help out other by using the rating system and marking answered questions as "Answered"*****
