wireless signal testing tool
b.withrow
Level 3
Level 3
Our company has a centralized IS department. We go out to the remote sites, do a site survey and install a wirless network. But over time the layout of the building may change and that in turn will cause a change in RF reception. I am looking for a small, simple device that I can give to a user at the remote site, so they could verify signal quality. One thought was a cheap PDA with a 350 card and ACU. Another thought was a product called 'Airmagnet'. Does anyone have experience with this type of device?
we are using airmagnet on ipaq and laptop and we are very happy with it. it isnt that cheap but you can make really much things. sitesurvey, security ches and so on
have a look at www.airmagnet.com
bernhard
