Wireless Solution
sbrici_ltt
Community Member
Hi there,
Currently I have 3 Linksys wireless routers one on each floor of our office.
WRT54G - Wireless-G Broadband Router
However, they are not working very well, and continuously dropping connection.
We are looking for a more corporate robust wireless solution. Perhaps one for the whole building.
Is there anything you recommend? (Preferable below the $2500 mark)
/sbrici
larrywoods
Go away with the Linksys in this scenario because it will not help roaming that well because they are made for single AP type scenarios. If I were you, I would look at the Cisco 1100 Series Wireless AP Model. You can get the ABG 1130 for $700 list and you should be able to get a discount if you go through a partner. So, 3 of those guys would be below your budget unless you try to get outside help for the installation.
