Wireless Survey Requirement
MAOsman
I want to conduct a wireless survey for cisco C9120AXI-E. Do I need a controller to accomplish the survey or I can just start the survey before deploying the controller, and if this is possible how should I do it?
Thanks in advance
JPavonM
@MAOsman yes you can only use the C9120 AP to perform the physical survey. Check this guide to convert it to AP with embedded controlelr to configure it with the same features and values you will use in the final deployment.
Hope this helps.
JPavonM
Hope this helps.
balaji.bandi
if this is large deployment i would suggest to use professional kit, the survey output can also be used in maps.
Ekahau Pro software with SideKick
still you looking to do survey use Cat 9K AP below video can help you.
https://www.youtube.com/watch?v=zqeFwL534m8
BB
