Wireless throughput
linhthasack
I ran several throughput check over a wireless bridge (1400) which is connected to eachother at 54M rate. My through put is 10Mbs down and 20 Mbs up download and upload are done seperately. This is an end to end test within our network. Any ideas why i am not getting anything close to 54 Mbs?*****INPUT PLEASE************
rhobab
Level 5
Level 5
You will never be able to get 54Mbs throughput. The wireless conection is half duplex so if you get close to 22Mbs throughput then you have a very good link.
rhobab
Level 5
Level 5
Thank you for your reply. I really appreciate it.
