Wireless user authentication using ACS
shijomon scaria
Level 5
Level 5
Hi All,
I am setting up a wireless network using 1252G-A-K9 LWAPs and WISM modules. Using WCS server also. I want to set up wireless user authentication using ACS and RADIUS. Please help me for the same.
Rgds,
Shijo.
Surendra BG
Hi Shijo,
Here is the link to configure what you need..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml
lemme know if this answered your question!!
Surendra
Please dont forget to rate the usefull posts which answered your question or was helpfull
Surendra BG
12 Replies 12
Surendra BG
Hi Shijo,
Surendra
Surendra BG
Where can i get the Aironet Desktop Utility...
Shijo.
Go for any Client device that you are using currently.. ADU is not mandatory..  and make sure you configure theexact settings on the client as well..
Lemme know if this helps..
Surendra
please dont forget to rate the usefull posts which answered your question or was helpfull
Surendra BG
I am trying to authenticate from a lap top, where i couln't find out any specific options or LEAP in the adaptor settings.
Rgds,
Shijo.
if you have a intel adaptor.. please donwload the intel proset and see what happens..
Surendra
please dont forget to rate the posts that answered your question or was helpfull
Surendra BG
I am using a dell wireless 1395 wlan mini-card.
Rgds,
Shijo.
The adaptor supports the below..
http://accessories.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=430-2742
So i guess you need to search the DOC which tells us how to configure the adapter..
Surendra
Surendra BG
Boss,
Actually this network expects almost 1000 users. In such a case is it possilble to configure each and every client machines in such a way?? The users may anticipate only a user name an password. Is there any other methods are available in ACS ??
Rgds,
Shijo.
Surendra BG
did that answer your question??
Surendra BG
Let me try it please....
Shijo.
shijomon scaria
Level 5
Level 5
The issue is resolved with ur help. Now my wireless clients are authenticating on ACS using leap. Thank you very much for ur support and patience.
Rgds,
Shijo.
WOW!!!
Thats nice to hear!! it was pleasure assisting you!! looking forward for some more posts from you..
Surendra
Surendra BG
