Wireless Video Issues
tlchant
I am trying to run wireless video over our wireless link and with the Cisco 1200 running at 54Mbps vs. 11 mbps. The 11 out performs the 54mbps by a wide margin. The AP is running IOS 12.2(13)JA. I will try upgrading to JA4.
Any thoughts.
Not applicable
I think I've seen a bug similar to what you're describing. You might want to check the bug tool kit.
scottmac
Level 11
Level 11
Is the AP set for "Throughput" or "Distance"(or Custom)?
What is the bit-rate of the video your are sending?
Are all of the visible clients running G, or is there a mix of B and G?
Scott
