Wireless Virtual Controller and 2504 - supported APs
Khaled Bamohamed
Community Member
I was working to propose a solution for a small customer where only 10 AP is required.  I have selected 1600 Series.
I checked the supported controller but unfortunately, I could not find a confirmation if virtual or 2504 controllers will support these access points.
It will be expensive to propose 5500 Controller.
I would like to know if 1600 AP is supported in Virtual Controller or in 2504 Controller???
6 Replies 6
Leo Laohoo
Both controller will support the 1600 as long as the controllers are running 7.4.100.0 firmware.
Software Release Support for Access Points
Thanks alot leolaohoo...
your response is quick and very helpful ...
Glad to be of some sort of assistance.
Scott Fella
Just to add to Leo's great response:)
Keep this link handy as it will tell you the compatibility for many if not all of the Cisco Wireless
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
Thanks Scott.  Handy link (hope it gets updated regularly).
It better or else we will just bug Surendra!  hahaha
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
