Wireless VLANs
pcfreak49
Level 7
Level 7
I have a question about the 800 16 wireless LAN you can make you that both 2.4GHz and 5GHz on?
28 Replies 28
Surendra BG
Scott Fella will be the right person to answer this question..
Scott,
I request you to pitch in..
Surendra
Surendra BG
+5 Surendra you are funny... Leo has the answer
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
You're both wrogn.
(I meant the post ABOVE.)
I think PCfreak is rating some post today! Wow .. Thanks for supporting the rating system ...
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
George Stefanick
A single AP can only broadcast a max of 16 SSIDs. You can however make many more SSIDs and VLANS but this would require AP groups.
Leo Laohoo
Anyone of you gents planning to implement 802.11ac?
Message was edited by: Leo Laohoo TYPE-O
@Leo... I have it running on one of my 3600's but I don't have any AC wireless cards:)
-Scott
Same here, Scott.  I got an eco-box of 3600 but we installed just one.  We don't want to let the rest of the organization know that there's a 802.11ac-ready AP somewhere in the building or the rest of these clowns will want it so "they use their iPhones to surf the net faster."
because the interfaces subinterfaces dotradio11 0.16 I got it no problem, the problem lies in creating subinterfaces interface gigabit ethernet 0.15 because then I get the message This platform supports only 16 vlans on this interface.
Sounds like you are using a autonmous ap not a WLC. On autonmous its a 1 - 1 mapping
what you mean
and if you change the IOS
What AP do you have and is it autonomous or lightweight?
-Scott
I 800 series
So which 800 series router do you have. It's a router/ap correct?
-Scott
