WiSM Refrence & Config Guide
with_joerg
All,
I am looking for a command refrence or some documentation about the WiSM. We are going to purchase a WiSM but it seems as if there is even less documentation than for the WLSM.
Where can I find a command refrence or sample configs?
--JOerg
Hi Joerg,
under http://www.cisco.com/en/US/partner/products/hw/modules/ps2706/prod_technical_reference09186a0080702fe2.html
you find the Guide you asked for, maybe ist is only available for Partners. Instead the Blade has integrated 2 independent Controller Modules the Configuration is similar to a standalone controller.
Regards, Michael
Right.
I cannot access it although we have a PICA account.
Isn't this "akward"? I mean it is the end customer who buys it and needs to live with the product.
Hmm, is there a way to discuss your Problems outside? I am installing 2 WiSM?s in a few weeks, maybe i have some answers. Your Name sounds German, right?
Regards, Micael
You can write me to
joerg (punkt) fritsch (at) nc3a (punkt) nato (punkt) int
