03-26-2012 01:21 PM - edited 07-03-2021 09:52 PM
WiSM WLAN Service Module WS-SVC-WISM-1-K9 in 6509e running VSS IOs s72033-ipservicesk9_wan-mz.122-33.SXI2a.bin having trouble to get the IP from service-vlan DHCP also status LED 1 & Status LED 2 showing off.
The pertinent config is as follows.
vlan 300
name WiSM_Service_Vlan
interface Vlan300
description *** WiSM Service-Vlan
ip address 192.168.200.1 255.255.255.0
ip dhcp excluded-address 192.168.200.1
ip dhcp pool WiSM_Service-Vlan_300
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
wism service-vlan 300
vlan 183
name WiSM_Management
interface Vlan183
description *** WiSM Management Vlan ***
ip address 10.39.139.254 255.255.255.0
wism switch 1 module 4 controller 1 allowed-vlan 125,126,183,300
wism switch 1 module 4 controller 2 allowed-vlan 125,126,183,300
wism switch 2 module 4 controller 1 allowed-vlan 125,126,183,300
wism switch 2 module 4 controller 2 allowed-vlan 125,126,183,300
wism switch 1 module 4 controller 1 native-vlan 183
wism switch 1 module 4 controller 2 native-vlan 183
wism switch 2 module 4 controller 1 native-vlan 183
wism switch 2 module 4 controller 2 native-vlan 183
HO2NET0001#sh wism status
Service Vlan : 300, Service IP Subnet : 192.168.200.1/255.255.255.0
WLAN
Slot Controller Service IP Management IP SW Version Status
20 1 0.0.0.0 0.0.0.0 Service Port Up
20 2 0.0.0.0 0.0.0.0 Service Port Up
HO2NET0001#sh module
Mod Ports Card Type Model Serial No.
1 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL13442Q5N
2 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL13442GAL
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL13410N8P
4 10 WiSM WLAN Service Module WS-SVC-WISM-1-K9 SAD133101UY
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL13442JE4
Mod MAC addresses Hw Fw Sw Status
1 0025.84f1.55b8 to 0025.84f1.55bf 2.1 12.2(18r)S1 12.2(33)SXI2 Ok
2 0025.84f1.4e58 to 0025.84f1.4e5f 2.1 12.2(18r)S1 12.2(33)SXI2 Ok
3 0027.0da7.c240 to 0027.0da7.c26f 3.2 12.2(18r)S1 12.2(33)SXI2 Ok
4 0023.5e25.7168 to 0023.5e25.7177 2.3 12.2(14r)S5 12.2(33)SXI2 Ok
5 001f.9e2a.2608 to 001f.9e2a.260f 3.1 8.5(3) 12.2(33)SXI2 Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3C SAL13442EG9 1.4 Ok
2 Distributed Forwarding Card WS-F6700-DFC3C SAL13442H9T 1.4 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL13442HU9 4.1 Ok
4 Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAD133200D6 2.1 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAL13442E5S 1.1 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL13421AJZ 2.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
HO2NET0001#sh vlan
300 WiSM_Service_Vlan active Gi1/4/9, Gi1/4/10
The service IP is supposed to have been populated with an address from the dhcp pool. I am also unable to connect to access it by console as well as doing a session switch 1 slot 4 processor 1. I get the following upon attempting to do so:
Through Console.
It is giving following & then got stuck.
Bootloader 3.2.202.0 (Nov 13 2007 - 19:35:12)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
CPU: 999 MHz
CCB: 333 MHz
DDR: 166 MHz
LBC: 41 MHz
L1 D-cache 32KB, L1 I-cache 32KB enabled.
I2C: ready
DTT: 1 is 33 C
DRAM: DDR module detected, total size:512MB.
512 MB
8540 in PCI Host Mode.
8540 not PCI Arbiter.
Memory Test PASS
FLASH:
Flash Bank 0: portsize = 2, size = 8 MB in 142 Sectors
8 MB
L2 cache enabled: 256KB
Card Id: 1537
Card Revision Id: 1
Card CPU Id: 1287
Number of MAC Addresses: 32
Number of Slots Supported: 4
Serial Number: FAM133200D6
Manufacturers ID: 30464
Board Maintenance Level: 00
In: serial
Out: serial
Err: serial
.o88b. d888888b .d8888. .o88b. .d88b.
d8P Y8 `88' 88' YP d8P Y8 .8P Y8.
8P 88 `8bo. 8P 88 88
8b 88 `Y8b. 8b 88 88
Y8b d8 .88. db 8D Y8b d8 `8b d8'
`Y88P' Y888888P `8888Y' `Y88P' `Y88P'
Model SVC-WiSM S/N: FAM133200D6
Net: TSEC ETHERNET
IDE: Bus 0: OK
Device 0: Model: STI Flash 8.0.0 Firm: 01/17/07 Ser#: STI1MMJ109198093647
Type: Removable Hard Disk
Capacity: 488.7 MB = 0.4 GB (1000944 x 512)
Device 1: not available
Booting Primary Image...
Press <ESC> now for additional boot options...
Detecting Hardware . . .
Cryptographic library self-test....passed!
XML config selected
Validating XML configuration
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 5.2.178.0
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Internal Interfaces: ok
Initializing Network Services: ok
Initializing Licensing Services: ok
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting FIPS Features: ok : Not enabled
Starting Fast Path Hardware Acceleration: ok
Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Client Troubleshooting Service: ok
Starting Management Frame Protection: ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting Certificate Database: ok
Starting VPN Services: ok
Starting Security Services: ok
Starting Authentication Engine: ok
Starting Mobility Management: ok
Starting LOCP: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting WLAN Control Protocol (WCP): ok
Starting Mesh Services: ok
Starting TSM: ok
Starting CIDS Services: ok
Starting Ethernet-over-IP: ok
Starting DTLS server: enabled in CAPWAP
Starting FMC HS: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting Management Services:
Web Server: ok
CLI: ok
Secure Web: Web Authentication Certificate not found (error). If you cannot access management interface via HTTPS please reconfigure Virtual Interface.
(Cisco Controller)
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
Would you like to terminate autoinstall? [yes]:
AUTO-INSTALL: starting now...
Through Session
HO2NET0001##session switch 1 slot 4 proc 1
The default escape character is Ctrl-^, then x. You can also type 'exit' at the remote prompt to end the session Trying 0.0.0.0 ...
Any assistance or ideas offered will be greatly appreciated.
03-26-2012 01:59 PM
Hi Tabish,
How many times do you have to open this same topic?
In my opinion, this is your THIRD thread for the same topic.
