WLAN AP C9130AXI-E session timeout
Gehrig_W
Level 6
Level 6
Hello Cisco WLAN Experts,
I'm busy with Cisco TAC to troubleshoot a SIP-call-problem via WLAN.
We would like to debug a little on a new Cisco AP C9130AXI-E and to enter "devshell".
But unfortunatly, my terminal-session is closed after short time of inactivity.
On 2800-WLAN-APs I used the following command to avoid this:
AP # debug capwap console cli
AP # config t
AP(config) # line console 01
AP (config-line) # exec-timeout 0
AP (config-line) #
These commands are no longer working on the new C9130AXI-E WLAN AP.
Who knows the command to avoid premature terminal session disconnect ?
Please check and come back with information.
I found the command by myself in the meantime.
After entering the enbale-command, the command exec-timeout is available.
Thank You
Wini
Arshad Safrulla
devshell is accessible only by Cisco TAC. I highly recommend not to play with this unless directed by TAC.
The command you referring to in COS-AP sets the session timeout for privilege mode and config mode.
Arshad Safrulla
