Cisco WLC 5520 AVC statistics
Spleens990
I'm trying to programmatically get AVC stats from my wireless controller. The equivalent of the output of:
show avc statistics top-apps
Other than Netflow (I'm not sure I can get this exact data with netflow) what is the best way to get this data? Is it available via SNMP? Do I have to scrape an ssh session?
Any insights would be appreciated.
patoberli
I only know the way of using Netflow. Positive thing with that is, you can utilize the netflow application of your choice. Important there, the netflow application does all the computation. There are some limitations with the netflow data of the WLC, depending on the software release:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/wireless_quality_of_service.html#netflow
Alternatively you probably need to use SSH.
