WLAN configuration when WLC is behind a FW
TrickTrick
Level 3
Level 3
In a scenario I'm working on, I have a WLC located behind a FW in a dedicated DMZ (let's say vlan 100), created a management interface to manage APs (interface in vlan 100, with FW ip as a GW in that vlan)
APs are located in the inside, in a different vlan, and are able to register with the WLC no issues.
now I want clients to get valid IPs from DHCP (VLAN 200 in the inside), but I can't create a WLAN interface in the same subnet as the VLAN in the inside part of the network (obviously when I do that the WLC becomes unreachable, and of course it's not recommended to extend the L2 network between the DMZ and the inside)
I think there's a way to create WLANS in the WLC with a subnet mapping between those wlans in the DMZ and the correspondent VLANS in the inside of the network, so the wireless clients can get IPs from the dedicated dhcp scope in the DHCP server (windows server) located in the inside as well
How can I achieve this please ? any document or information is highly appreciated
Thank you
31 Replies 31
Thank you, I got your point, I've put the WLC<=>SW as a trunk, for the the rest I have it already as mentioned in the diagram, for now I'm trying to use only the internal DHCP to avoid any misconfig in the DHCP server itself since I don't have a control over it, but still no success !
Access point can stay in access mode right? (no need to trunk it as well)
For local mode, central switching, everything is tunnelled to WLC over CAPWAP and the switchport can be an access port because it's only being used for the AP's CAPWAP connection to the WLC.
For flexconnect local switching it must be a trunk port.  The native VLAN is your CAPWAP/management VLAN (whatever you configured for the access port) and the rest of the VLANs are tagged for the WLAN traffic to break out locally on the switchport.
Thank you, learned something new today,
so in that case, let's say I will choose local mode, the CAPWAP is able to tunnel vlans to WLC even if those vlans are not extended to the DMZ to point on their respective interfaces there ?
in Flex mode, I don't need interfaces in the WLC since everything is locally switched, but how the AP/switch will differentiate a mobile user from another to give the right IP from the right vlan, because in local mode I think it's the interface of the WLAN itself which does that job as the ip helper of that subnet
Also, in flexconnect mode, is it possible to use the internal DHCP of the WLC or, since everything is locally switched, the LAN DHCP should be used.
Thank you
Yes but it would be completely pointless if you terminated them on the WLC which didn't have them connected to anything!
Local switched traffic is just dumped onto the VLAN (layer 2) just like for a LAN connected user.  So you need the IP interface on a switch or router on that VLAN and that's where the helper address will be.  The AP and WLC play no part in that.
Flexconnect allows LOCAL SWITCHING for the WLAN (you can still have other centrally switched WLANs on a flex AP).  Locally switched WLANs should use the LAN DHCP.
Thank you for your explanations, Gor it fixed by applying what you explained
sorry for asking again, I still have an issue understanding flexconnect mode, is there any blog explaining the details of that mode and how it works so I can get it (i've seen in some deployments flexconnect mode deployed and at the same time we have interfaces created for the WLANs)
Google is your friend - plenty of info to be found if you look ...
Some examples:
https://www.kareemccie.com/2017/08/what-is-flexconnect.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/flexconnect.html
https://networklessons.com/cisco/ccna-200-301/cisco-wireless-ap-modes#FlexConnect
You config FLEX AP
1- Local Switching
This can easily done even if WLC behind the WLC
VLAN management <- this already config in SW and FW
VLAN DHCP <- this already config in SW and FW
VLAN USER <-  1-config VALN in SW
                         2-config subinterface in FW
                         3- since the DHCP is not in same Broadcast with VLAN of USER and there is FW you need
                         DHCP reply in each VLAN USER to convert Broadcast to unicast and send it to DHCP Server.
that it friend this all you need
2- Central Switching
this hard to config because you need for each WLAN VLAN and hence SVI and sub interface in DMZ.
note:-need this in FW
same-security-traffic permit inter-interface
please check the diagram attached to my reply, it's my actual configuration, what I missed compared to what you have mentioned ?
Thank you
Management WLC VLAN is 200 and also it native VLAN of SW1
Management AP VLAN is 50 and also it native VLAN of SW2 or tag ? Just to be sure are you use AP management "AP get this IP from DHCP" to build the CAPWAP tunnel ? the tunnel is UP and AP can join the WLC "behind FW"?
Any way as mention before,
1-FLEX MODE
2-WLAN is LOCAL SWITCHING
3-DHCP VLAN 100, and also config the sub interface in FW
4-VLAN 200 subinterface in FW config DHCP reply to convert broadcast to unicast forward to DHCP server in VLAN 100
that it.
ammahend
Now I want clients to get valid IPs from DHCP (VLAN 200 in the inside), but I can't create a WLAN interface in the same subnet as the VLAN in the inside part of the network.
You can try and create a dynamic interface for vlan 200 on WLC, map it to a dedicated port on WLC and connect the port to inside interface on Firewall, which also will be the gateway for vlan 200.
-hope this helps-
I got your point, the client won't accept it though because it will bypass the firewall, my main question now is, should i absolutely have a wlan interface in the same network as the vlan i want to create ssid for ? What architectures do in such design?
bypass FW!!!! how that ??
the SVI GW of user VLAN is config in FW
the SVI GW of DHCP VLAN is config in FW
the traffic pass through FW how it bypass?
Again this for local not central SW.
Central SW need to config the sub interface in DMZ not in INSIDE
I haven't tried it myself, was just telling a way to do it, seems like you are still in design phase of this, so lets take a step back, why you planning to have WLC in DMZ ?
-hope this helps-
Hmm, We are not in the design phase, the client wanted all its servers to be centralized in the DC, and have only some admins from the inside to have access to them (DHCP, DNS in a zone... Applications in a separated zone, ISE and Prime in a zone, And WLC in a separate zone on its own), all of these zones are in the FW created for security and visibility purpose
