WLAN configuration
shaikh.zaid22
Level 6
Level 6
I have 9800 WLC configured with single WLAN and shared across all the org departments for corporate resource access.(Forescout NAC recently deployed)
recently we have segregated all the org departments into separate vlans and disallowed inter-vlan communication as part of compliance requirement.
Now, my requirement is, i need to create one or utilize the existing WLAN in such a way that when for instance if a finance user connects to the WLAN, the user should receive ip address from the same finance subnet range (say vlan 32). Similarly, i have to accomplish for all departments.
How shall i approach this use-case in the WLC configuration.
Need your guidance and assistance in this regards folks.
Haydn Andrews
802.1x Authentiated SSID with AAA Override
RADIUS server returning seperate VLAN ID dependant on the policy matched to identify which group a user is from.
Not a forescot NAC setup but here is the config guide for doing it with ISE the principles will be the same
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/217043-configure-dynamic-vlan-assignment-with-c.html
If using local mode, need to ensure the VLANs are trunked to the 9800. Flexconnect need to ensure the VLANs are trunked to the AP and defined in the Flex Profile
*****Help out other by using the rating system and marking answered questions as "Answered"*****
6 Replies 6
Mark Elsen
 - Review this document : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/dhcp-for-wlans.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Haydn Andrews
Hi Haydn,
Thank you for the document. It really made me understand with all necessary configuration.
Just one more thing here, since we have users integrated via AD, and in this doc the users are created locally in ISE and Vlan was assigned manually in the user identity for Vlan 102 assignement here.
So via AD, how i can achieve this? Do i need to tweak the user settings in the AD user account details with specific Vlan X ?
hi Haydn,
Thank you for the reference document. I was able to get it done successfully with Forescout NAC.
brother I am also facing the same with wlc9800, 802.1x and forescout, may I know how you sorted out ? Thanks
This can be done on Forescout, after reading the department details of the connected user , it can move the user to respective vlan. This u can do after assessing the connected endpoint and configure the control action to move the user into proper vlan.
