wlan controller connections
juanluisrodriguez
Community Member
I have two options when connecting wlan controller 4404:
1) to a 2600 router (outside internal lan)
2) to a 2900 catalyst (inside lan)
Which one should I take as the best one ?
pradeepde
Level 11
Level 11
By default, controllers block Telnet sessions. You must use a local connection to the serial port to enable Telnet sessions.
direct ASCII serial connection to the controller console port
A remote console session over Ethernet through the pre-configured Service Port or through Distribution System Ports
Before you log into the CLI, configure your connectivity and environment variables based on the type of connection you use
