WLAN Controller failover for Lightweight Access Points for four controller
In our project there are four wireless controller in two wism -1 module and 211 APS 1042
for WLC1 fail over is WLC4
and for WlC2 Fail over is WLC3
for each APS in High availbility we have to assign primary and Secondary
is there any cli commad or gui  to configure in controller so that one controller of APS are backup of second controller
2 Accepted Solutions
Leo Laohoo
config ap secondary <controller name> <AP name> <controller Management IP address>
config ap primary <controller name> <AP name> <controller Management IP address>
Sandeep Choudhary
1. Best would be if you have prime infra or NCS then you can push via Lightweight AP templets.
2. You can use these command:
(WLC) >config ap primary-base WLC2 AP002 10.XX.80.3
(WLC) >config ap secondary-base WLC1 AP002 10.XX.80.1
- prepare a notepad, list all AP name and then copy paste these commands on WLC
Dont forget to rate helpful posts
Leo Laohoo
Sandeep Choudhary
