wlan design issue
I'm designing the wlan solution for a client.
Our requirement is to have two SSIDs along with remedy vlan(quarantine vlan).
1. Corp
        Corporate traffic will be locally switched(Cisco wlc H-REAP mode). If software check fails users must be moved to remedy vlan.
2. Guest(tunneled to anchor using LWAPP)
My doubts are,
1. We use openradius for user authentication. WLC uses the "SNMP set" operation to implement the remedy vlan. Whether wlc supports radius(.1x) to configured the vlan dynamically.
2. Remediation server is deployed in Datacenter. corp vlan & remedy vlan(quarantine vlan) share the same wlan ssid. How to enable local switching for corp.vlan & tunneling for remedy vlan.
3. Is there any other way to implement remedy vlan apart from cisco's inbuild quarantine vlan solution.
Ramesh
Nicolas Darchis
WLC Quarantine vlan is for use with Cisco Clean access, not on its own.
As far as I know, you can't do vlan assignement with hreap local switching SSID anyway
