WLAN design question
scdigital
Community Member
Can someone tell me what the best configuration is for the following scenario:
Site1 (Head Office & Data Centre)
100 users
Site2
80 users
Site3
40 users
Site4
40 users
Site5
30 users
Each of the sites has its own Domain Controller.
My idea is to have a vWLC at Site1 and configure AP's in H-REAP/Flexconnect mode at each of the other sites with local switching and radius authentication on the local DC.
Is this a feasible design or is there a better way?
6 Replies 6
Leo Laohoo
Are you planning to use Catalyst 3850 as your LAN switch at each site?
If you are, then you can use the 3850 to terminate 50 APs at a time and enable the WLC.
Most switches will be 3560's.
Site 1 will have 4507.
Each site will need less than 5 AP's.
Well then, if you will have an authentication server at each site then H-REAP is a very ideal choice.
Scott Fella
I think the max AP that is supported on a vWLC is 200? You have over 200 AP's.
-Scott
We have over 200 users, not AP's.  We have around 25 AP's maximum.
Your right;:)
-Scott
