WLAN for Guests
Jbelec8151
Community Member
We have a 5508 controller, one WLAN, and all of our internal wireless goes through that. We are looking into starting a guest WLAN. The internal wlan goes through one VLAN. What is going to be the best way to set up the guest wlan? I am assuming that I may need to provide more information, so just let me know.
Thanks!
6 Replies 6
Stephen Rodriguez
Create a new VLAN for the guest network, and ACL the hell out of it so that it can only get to the internet, and nothing internal.  Trunk it to the WLC
Create an interface on your WLC in this new VLAN.
Create new WLAN and select the new 'guest' VLAN interface.
Test.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Haha.. Steve makes it sound so easy.
Here are some links just in case.
Multiple vlans
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805e7a24.shtml#t2
ACL on the WLC (I prefer to do this on the router)
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807810d1.shtml
-Scott
Hey, if I can do it!
lol
HTH,
Steve
HTH,
Steve
I looked at your post and I said to myself, "oh man... easy for someone who has done a million times".  hahaha
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
manbaez
Level 3
Level 3
Please download  document http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/wlc_cg7_2.pdf
go thru document...
There are several ways to do this... depends your topology... security... and controls... that your company have, chapter 11 will help you to setup this type of security and controls
Abhishek Abhishek
Hello Jayson,
As per your query i can suggest you the following solution-
Complete these steps in order to configure the devices for this network setup:
1.Configure Dynamic Interfaces on the WLC for the Guest and Internal Users
2.Create WLANs for the Guest and Internal Users
3.Configure the Layer 2 Switch Port that Connects to the WLC as Trunk Port
4.Configure the Router for the Two VLANs
For more information please refer to the link -
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008070ba8f.shtml
Hope this will help you.
