WLAN icons
does anyone know where I can download the latest Cisco device icons to import into a network design etc, especially the newer AP's
thanks
5 Replies 5
Scott Fella
You can look here for free visio or ppt icons:
http://www.cisco.com/web/about/ac50/ac47/2.html#doc_print
If you feel like paying, you can go to netzoom.com... they can create icons for you.
-Scott
Thank you Fella... i was looking for this as well...
cheers
mick
Thanks for that but it doesnt actually have any icons for Ap either generic or specific models, any ideas where else i can get some?
For the 1252 or the 1140's and others, you will have to go to netzoom for those. I don't think Cisco has released them as you can see from the file you downloaded.
You are actually looking for an icon that looks like the AP correct?
Sorry the paid site is: http://www.altimatech.com/home/index.php
http://www.netzoomuniversal.com/home/customer_download_area.asp
-Scott
