wlan id
Nana Banahene
Level 2
Level 2
On a 2504 running 8.3.102 if one wants to create a wlan with wlan ID starting at 17(to bypass default AP-Group), how does one accomplish that?  Once that is created, I can map it to AP Group but can't create it in the first place cuz i am limited to 1-16. Any suggestions will be appreciated.
Can one create a wlan starting with 17?
Not possible.
Leo Laohoo
With a large big rock.
2504 is only limited to support 16 SSID and therefore 16 WLAN IDs.  There is no way to increase the amount of WLAN IDs.
With a large rock huh, Lmao. Let me clarify...I want to create 10 wlans starting with wlan ID 17. I dont want to use 1 through 16 cuz APs will fall into the default group. Can one create a wlan starting with 17?
Not possible.
