07-13-2016 09:34 AM - edited 07-05-2021 05:25 AM
I have to deploy an architecture of 30 remote offices with access-point controlled by vWLC in flexconnect mode.
Each office need a centrally switched WLAN, and 2 specific WLANs locally switched.
Each specific WLAN has a different SSID, so I need 30 groups and 61 WLANs.
Each group has a common WLAN and 2 specific WLANs.
How can I configure all my WLANs and SSID?
My controller supports only 16 WLANs.
thanks all
Johnny
07-13-2016 11:19 AM
Hi Johnny,
The description that you provided is slightly confusing. WLAN and SSID mean the same thing. Are you referring to WLAN profile when you say WLAN?
I may be able to help you if you can clarify this.
Best Regards,
WiFi Trainers (www.wifitrainers.com)
Your one stop solution for all your wireless training needs!
******** Please rate if useful *********
07-14-2016 01:14 AM
Yes I meant WLAN Profile.
I need more than 16 WLAN Profile.
Is it possibile?
