wlan optimisation
polinux1
Community Member
we actually have lan and wlan (wifi)on external internet provider and we plan to add a wlan wifi) linked to the lan.
we have aprox. 100 users and have active directory authentification.
What is the device should we use and how can we manage the authentification ?
Many thanks in advance.
PR
Justin.Nichols
Just a couple of question to clarify.
1. Do you currently have a WLC?
2. If so are you using 802.1x RADIUS authentication on the WLC back to your AD/NPS server for wireless client authentication?
Saurav Lodh
Level 11
Level 11
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69730-eap-auth-wlc.html
