wlan switch and appliance difference
cfajardo1_2
Level 7
Level 7
hello,
anyone knows whats the difference between the airespace wlan switch and the appliance?
thanks
stschmidt
Level 6
Level 6
I am not sure which switch and appliance you are referring to.
Cisco Wireless LAN Controllers are responsible for system wide wireless LAN functions, such as security policies, intrusion prevention, RF management, quality of service (QoS), and mobility. They work in conjunction with Cisco 1000 Series Lightweight Access Points and the Cisco Wireless Control System (WCS) to support business-critical wireless applications.
http://cisco.com/en/US/products/ps6366/index.html
Check out the data sheet for detailed information.
Cisco Wireless Location Appliance
This easy-to-deploy solution smoothly integrates with Cisco Wireless LAN Controllers and Cisco lightweight access points to track the physical location of wireless devices including Wi-Fi enabled laptops, voice handsets, Wi-Fi tags, rogue devices and rogue access points to within a few meters. This appliance also records rich historical location information that can be used for location trending, rapid problem resolution and RF capacity management.
http://cisco.com/en/US/products/ps6386/index.html
The appliance is used on the network management side.
Hope this helps.
