WLAN Users Authenticate sometimes to Radius
WLAN users sometimes authenticate to the Radius JUST fine, some other times they take forever and they are timed out.
Any hint as to where i should look first?
Has anyone seen this problem?
Stephen Rodriguez
You could run a debug client < client mac address >
to see what is happening.  You could also check the logs on your AAA server to see if there was a reject, or if it just didn't respond.
You can also take a look at the EAP timers,
https://supportforums.cisco.com/docs/DOC-12110
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
