WLC 2006 Management interface
tschwimer
Community Member
I have my WLC configured as follows:
management intf - 10.10.254.42
ap-manager intf - 10.10.254.41
Both are untagged, and the switch port has the native vlan set to 1.
However, I am unable to reach either address from any other subnet. What gives?
ankbhasi
Hi Friend,
Can you ping your gateway from your controller? Can you ping this controller from anywhere in your network if you TAG the interfaces instead on untagg?
Ankur
