WLC 2112 is not accessable
GR-IT-Network
Beginner
Beginner
Hello Experts,
I have a problem with my Cisco WLC 2112.
Problems:
1. I can not reach this WLC via GUI or CLI.
2. Can not access via Console.
3. Status LED is Dark Orange or Red.
Can anybody help.
3 Accepted Solutions
Status LED is Amber(ORANGE/RED)— Means Problem encountered during boot.
http://www.cisco.com/en/US/docs/wireless/controller/2100/quick/guide/ctrl206q.html#wp39363
Did u tried with these settings:
9600 baud
8 data bits
No flow control
1 stop bit
No parity
If the console is not responsive, then its a hardware failure and you should contact the TAC or You should RMA'd it.
Be aware: WLC 2100 Series are EOL/EOS.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps7206/ps7221/end_of_life_notice_c51-691053.html
Dont forget to rate helpful posts
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
Your WLC is dead. The status light is in alarm, so nothing you can do to fix that as that device is EOS also.
-Scott
Ok,
Power down the WLC and then power it back up and then see if the WLC comes back up and then try replacing the power supply and see.. if  still face the issue, then u have to buy new one 25500 or 5500 series.
9 Replies 9
9600 baud
8 data bits
No flow control
1 stop bit
No parity
Thanks for your quick Help.
Yes I have tried with these setting but still not able to access.
Ok,
Thanks....I will try to buy new one .
Thanks again  for all your quick help.
Scott Fella
Hall of Fame Guru
-Scott
Change the RAM, will sort the Boot issue :) 2 years late lol
Nearly 5 years on, following your advice has fixed my ancient 2106. It rolled over a few days ago after a neighbourhood power surge and I was all set to purchase a replacement from eBay when I came across this thread. A quick rummage in my old spares box produced a replacement RAM module and a few minutes later, WLC springs back to life. Thanks very much for the tip!!!
Our WLC went down yesterday, and I just ran across this thread. Sure enough, this fix worked for me as well. Replaced the RAM with a spare module from an old scrap Dell Dimension 4600. Worked great. Thanks!
alvaroke1
Beginner
Beginner
Well I must post here aswell it might help any1...In my case the RAM was only moved... so I removed the case, pluged in correctly the RAM... and voila!
Recognize Your Peers
