WLC 2504 and 1130AG
I have a 1130AG that has never been used. I cannot get it to see the WLC 2504 controller. It does pull a DHCP address. With the help of others here, I got the 3502I APs working.
Has anyone seen this issue before.
2 Accepted Solutions
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
-Scott
Yea that autonomous.
15 Replies 15
George Stefanick
Is the 1130 in autonmous mode or CAPWAP. What is the model number of the AP?
George Stefanick
Also did you put it on the managment vlan like with the 3500 ?
Yes, it is on the management VLAN, the model is AIR-AP1131AG-A-K9
Scott Fella
Is the 1131 lightweight or autonomous. If autonomous, you new to convert it to lightweight. If you can issue a config t it is autonomous. If it is lightweight, then post the output from the console.
-Scott
It must be autonomous, how cna I convert it to lightweight.
-Scott
LOL.. My link is better than yours scott!
Can the process be reversed if needed.
yup
Haha.... Too funny
-Scott
Scott Fella
George is pretty fast today:)
-Scott
Thanks for all your help today Scott and George
Here is a video that shows how to go back and forth from autonomous to capwap
http://www.youtube.com/watch?v=wWDrFjwVNb0
