WLC 2504 with Aironet 1704 APs
Hello experts,  @balaji.bandi  @Scott Fella  @Sandeep Choudhary  @Rob Ingram
I have two 1704 APs connected with 2504 Controller.
Both APs look fine within Controller login but Physically, One AP having green blinking light whereas other AP is having Solid Light.
The Other thing, I want to make sure is that as Both APs are just 30 feet apart, I want to make sure devices should be roaming bw APs while users moving within Building? how I should make sure this?
balaji.bandi
AP LED Status check here :
https://community.cisco.com/t5/wireless-mobility-documents/what-do-the-led-patterns-on-the-access-point-indicate/ta-p/3133183
Look at the roaming :
https://mrncciew.com/2014/09/02/cwsp-802-11-roaming-basics/
Note : End Device decides which AP to connect always,
BB
Leo Laohoo
Check the WLC for the IP address of this AP.  Is the IP address ping-able?
Yes, it is pingable and I can see it in the controller.
I think its showing the blink green light because no devices connected to it.  I enabled Fast Roaming on the SSIDs and I think it will be better.
Scott Fella
The 160x's and the 170x's led is different than the 2802 and 3802 as an example.  Blinking green means no clients and solid green means a client is connected.
-Scott
