WLC 3504 Communication with cisco air-ap 15421-e-k9
Ahmad Manzoor
Hi Guys,
Greetings !!
I have Cisco WLC Controller 3504, and also i have some (Cisco air-ap 15421-e-k9 Outdoor AP's) and i'm facing the issue with communication of these, controller and Ap's are in same vlan and dhcp are working in my vlan also option 43 is configured in my dhcp for push the AP to get resources from Controller.
when i plugged AP's to my network port, its take the IP from dhcp but its not discover the controller and not registered under controller its showing the below error,
"Enabling Controller Provisioning Can't open format specifier database File:No such file or directory at /bsn/xml2cli_optimized line 43."
the AP it's self boot up as a stand alone and broadcast the his default SSID.
If any one can help would be appreciate !
9 Replies 9
balaji.bandi
what is the version of code running in WLC.
can you connect to console to AP and post complete boot process to understand were went to wrong?
Other information required - any other AP joined this WLC  - none of them working ?
BB
Thanks for replay
please find the below WLC software version and entire boot-up process.
Controller Software Version 8.5.140.0
Board type: AP1542I/D
smem ram ptable found: ver: 1 len: 3
U-Boot 2012.07 (btldr release 36) (Oct 13 2017 - 10:35:07)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1022 MiB
Nand: Detected ONFI Winbond NAND 256MiB 3,3V 8-bit
NAND ECC=1 ECC_THRESHOLD(NAND ECC-1)=0
SF: Detected MX25L3205D with page size 4 KiB, total 4 MiB
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:1], write_counter=4
machid: 8010001
Net: MAC0 addr:a4:53:e:6a:6a:b8
AR8033 PHY 0
PHY ID1: 0x4d
PHY ID2: 0xd072
ipq40xx_ess_sw_init done
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part2
Booting from part2
Read 1024 bytes from volume part2 to 88000000
Read 42868375 bytes from volume part2 to 88000000
Signature returns 0
Image signing verification success, continue to run...
bootm 0x88000400
## Booting kernel from Legacy Image at 88000400 ...
## Loading init Ramdisk from multi component Legacy Image at 88000400 ...
## Flattened Device Tree from multi component Image at 88000400
Booting using the fdt at 0x8a8d8a50
Loading Ramdisk to 9d8f1000, end 9fffffe0 ... OK
Loading Device Tree to 9d8e5000, end 9d8f0c46 ... OK
no such device nand0
Using machid 0x8010001 from environment
Starting image ...
[01/01/1970 00:00:41.4799] Linux version 3.14.43 (vipendya@wnbu-bld-lnx9) (gcc version 4.7.1 (OpenWrt GCC 4.7.1 r48430) ) #1 SMP PREEMPT Sun Nov 25 05:39:12 PST 2018
[01/01/1970 00:00:41.6399] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[01/01/1970 00:00:41.7399] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[01/01/1970 00:00:41.8399] Machine model: Cisco 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:41.9199] Memory policy: Data cache writealloc
[01/01/1970 00:00:41.9899] Kernel command line: console=ttyMSM0,9600n8 ubi.mtd=0 root=/dev/ram activepart=part2 activeboot=0 wdgtriggered=0 board_sku=5 clk_ignore_unused
[01/01/1970 00:00:42.1699] CPU1: Booted secondary processor
[01/01/1970 00:00:42.2299] CPU2: Booted secondary processor
[01/01/1970 00:00:42.2999] CPU3: Booted secondary processor
[01/01/1970 00:00:42.3599] buginf tty flushing thread started, ttyport=beaf4400
[*01/01/1970 00:00:45.7599] buginf() enabled.
[*01/01/1970 00:00:45.7899] Made it into bootsh: Nov 25 2018 05:46:24
[*01/01/1970 00:00:45.7899] bootsh build T-b1c4d316cf409bad6ec9cbf2958c6014776e95f2-gb1c4d316-vipendya
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
error: open /dev/board-config
init started: BusyBox v1.23.2 (2018-11-25 05:20:04 PST)
[*01/01/1970 00:00:49.3099] GCM-128 POST passed
[*01/01/1970 00:00:49.3099] GCM-256 POST passed
[*01/01/1970 00:00:49.4499] === 5G radio domain is 12, COPY 5G BDF files from ETSI_BDF folder ===
[*01/01/1970 00:00:49.4999] 0
[*01/01/1970 00:00:49.6899] Active version: 8.5.140.0
[*01/01/1970 00:00:49.6999] Backup version: 0.0.0.0
[*01/01/1970 00:00:50.0999]
[*01/01/1970 00:00:50.0999] led pattern module start
[*01/01/1970 00:00:50.1399] Loading caldata from mtd2
Jan 1 00:00:50 FIPS[2899]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:50.5299] ess-switch DT exist!
[*01/01/1970 00:00:50.5299] switchreg_base_addr: 0xc000000
[*01/01/1970 00:00:50.5299] switchreg_size: 0x80000
[*01/01/1970 00:00:50.5299] switch_access_mode: local bus
[*01/01/1970 00:00:50.5299] wan bmp:0x20
[*01/01/1970 00:00:50.5299] ess-psgmii DT exist!
[*01/01/1970 00:00:50.5299] mac mode=3
[*01/01/1970 00:00:50.5299] current mac mode = 3
[*01/01/1970 00:00:50.5299] current dts led_source_num is 5
[*01/01/1970 00:00:50.5299] mdio DT exist!
[*01/01/1970 00:00:50.5299] ssdk_plat_init start
[*01/01/1970 00:00:50.5299] enable ess clk
[*01/01/1970 00:00:50.6399] reset ok in probe!
[*01/01/1970 00:00:50.6399] PHY ID is 0x4dd072
[*01/01/1970 00:00:50.7099] Dakota Chip version 0x1401
[*01/01/1970 00:00:50.7099] QCA Switch config done.
[*01/01/1970 00:00:50.7199] gcc map success!
[*01/01/1970 00:00:50.7599] qca-ssdk module init succeeded!
[*01/01/1970 00:00:50.7599] QCA Switch config done.
[*01/01/1970 00:00:50.9499] crypto worker thread started
[*01/01/1970 00:00:51.0099] pid 3169's current affinity mask: f
[*01/01/1970 00:00:51.0099] pid 3169's new affinity mask: e
[*01/01/1970 00:00:51.0199] pid 3168's current affinity mask: f
[*01/01/1970 00:00:51.0199] pid 3168's new affinity mask: e
[*01/01/1970 00:00:51.2499] Current value of FACTORY_RESET=0
[*08/31/2019 23:59:59.0099] Last reload time: Aug 31 23:59:59 2019
[*08/31/2019 23:59:59.0000] Setting system time Sat Aug 31 23:59:59 UTC 2019
[*08/31/2019 23:59:59.0699] device wired0 entered promiscuous mode
[*09/01/2019 00:00:02.1099]
[*09/01/2019 00:00:02.1099] Authenticating ACT2 ID:AP1540
[*09/01/2019 00:00:02.1099] Authenticating SN:FOC2331454B
[*09/01/2019 00:00:02.1199]
[*09/01/2019 00:00:02.1199] (ACT2Boot) Hardware is Cisco (c) authentic :-)
[*09/01/2019 00:00:02.1299] Seeding /dev/urandom from ACT2
[*09/01/2019 00:00:02.7599] Reading ACT2 SUDI certificates
[*09/01/2019 00:00:04.4399] stile module dp init successfully
[*09/01/2019 00:00:04.4399] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_20180404_162221 NBAR VERSION:module build date: Nov 25 2018 at 05:43:59
[*09/01/2019 00:00:04.7799] pid 3332's current affinity mask: f
[*09/01/2019 00:00:04.7799] pid 3332's new affinity mask: e
[*09/01/2019 00:00:04.7799] pid 3331's current affinity mask: f
[*09/01/2019 00:00:04.7799] pid 3331's new affinity mask: e
[*09/01/2019 00:00:04.7799] pid 3330's current affinity mask: f
[*09/01/2019 00:00:04.7799] pid 3330's new affinity mask: e
[*09/01/2019 00:00:05.4299]
[*09/01/2019 00:00:05.4399] boot 2 build T-b1c4d316cf409bad6ec9cbf2958c6014776e95f2-gb1c4d316-vipendya board mallorca mac A4:53:0E:6A:6A:B8
[*09/01/2019 00:00:05.4499] Module: mbedtls .text=0x7f000000 data=0x7f0075e0 bss=0x7f007840
[*09/01/2019 00:00:05.4499] Module: aptrace .text=0x7f00c000 data=0x7f017f88 bss=0x7f018470
[*09/01/2019 00:00:05.4499] Module: led_module .text=0x7f020000 data=0x7f020594 bss=0x7f020c04
[*09/01/2019 00:00:05.4499] Module: qca_ssdk .text=0x7f024000 data=0x7f0ba100 bss=0x7f0bfba4
[*09/01/2019 00:00:05.4499] Module: essedma .text=0x7f111000 data=0x7f117960 bss=0x7f117df4
[*09/01/2019 00:00:05.4499] Module: crypto_netdev .text=0x7f11f000 data=0x7f121e7c bss=0x7f1220e0
[*09/01/2019 00:00:05.4499] Module: act2_driver .text=0x7f12b000 data=0x7f12b76c bss=0x7f12b9f0
[*09/01/2019 00:00:05.4499] Module: proclikefs .text=0x7f12f000 data= bss=0x7f12fb80
[*09/01/2019 00:00:05.4499] Module: stile_lm_ft .text= data= bss=
[*09/01/2019 00:00:05.4499] Module: stile_lm_dp .text= data= bss=
[*09/01/2019 00:00:05.4499] Module: ipv6 .text=0x7fc76000 data=0x7fcaf000 bss=0x7fcb0600
[*09/01/2019 00:00:05.4499] Module: llc .text=0x7fcd7000 data=0x7fcd7844 bss=0x7fcd79d0
[*09/01/2019 00:00:05.4499] Module: stp .text=0x7fcdc000 data=0x7fcdc280 bss=0x7fcdc42c
[*09/01/2019 00:00:05.4499] Module: bridge .text=0x7fce0000 data=0x7fce8a98 bss=0x7fce8ed8
[*09/01/2019 00:00:05.4499] Module: p8022 .text=0x7fcf5000 data= bss=
[*09/01/2019 00:00:05.4499] Module: psnap .text=0x7fcf9000 data=0x7fcf9348 bss=0x7fcf94b8
[*09/01/2019 00:00:05.4499] Module: reed_solomon .text=0x7fcfd000 data=0x7fcfe3fc bss=
[*09/01/2019 00:00:06.0899] Last reload reason : 0: unknown
[*09/01/2019 00:00:08.3899] __mm_init_module
[*09/01/2019 00:00:08.4599] ol_ath_ahb_probe
[*09/01/2019 00:00:08.4599] ol_ath_ahb_probe: io resource start: 0xa000000, mem=0xc2800000
[*09/01/2019 00:00:08.4599] __ol_ath_attach() Allocated scn 9e0004c0
[*09/01/2019 00:00:08.4599] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000040
[*09/01/2019 00:00:08.4699]
[*09/01/2019 00:00:08.4699] ol_ath_ahb_configure : num_desired MSI set to 0
[*09/01/2019 00:00:08.4699] Using Legacy Interrupt
[*09/01/2019 00:00:08.4699] Waiting for target init
[*09/01/2019 00:00:08.4699] Done waiting
[*09/01/2019 00:00:08.4799] ol_ath_attach interface_id 0
[*09/01/2019 00:00:08.4799] Chip id: 0xb, chip version: 0x1000000
[*09/01/2019 00:00:08.4799] Target Version is 1000000
[*09/01/2019 00:00:08.4799] Flash Download Address c0000
[*09/01/2019 00:00:08.4799] ol_transfer_bin_file: flash data file defined
[*09/01/2019 00:00:08.4799] ol_transfer_bin_file[3918] Get Caldata for wifi0.
[*09/01/2019 00:00:08.4799] __adf_os_fs_read[42], Open File /tmp/wifi0.caldata SUCCESS!!
[*09/01/2019 00:00:08.4799] file system magic:16914836
[*09/01/2019 00:00:08.4799] super blocksize:4096
[*09/01/2019 00:00:08.4799] inode 3604
[*09/01/2019 00:00:08.4799] file size:12064
[*09/01/2019 00:00:08.4799] qc98xx_verify_checksum: flash checksum passed: 0x 361
[*09/01/2019 00:00:08.4799] ol_transfer_bin_file 3979: Download Flash data len 12064
[*09/01/2019 00:00:08.4999]
[*09/01/2019 00:00:08.4999] Board data initialized
[*09/01/2019 00:00:08.4999] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:08.5199] ol_ath_download_firmware :First OTP download and Execute is good address:0x5800 return param 4660
[*09/01/2019 00:00:08.5199] ol_ath_download_firmware:##Board Id 22 , CHIP Id 0
[*09/01/2019 00:00:08.5199] wifi0: Selecting board data file name boardData_Crete_Outdoor_2G_neg_pwr.bin
[*09/01/2019 00:00:08.5199] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_Crete_Outdoor_2G_neg_pwr.bin
[*09/01/2019 00:00:08.5199] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:08.5399] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:08.5599]
[*09/01/2019 00:00:08.5599] [Flash] : Ignore Module param
[*09/01/2019 00:00:08.5599] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/01/2019 00:00:08.5599] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:08.5699] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
[*09/01/2019 00:00:08.5699] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:09.7899] HTC Rx: insufficient length, got:4 expected =8
[*09/01/2019 00:00:09.7899] Startup Mode-0 set
[*09/01/2019 00:00:09.7899] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/01/2019 00:00:09.7999] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/01/2019 00:00:09.7999] Firmware_Build_Number:70
[*09/01/2019 00:00:09.7999] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht_cap_info:0x339959b2 vht_supp_mcs:0x0000fffa
[*09/01/2019 00:00:09.7999] RES CFG Support wmi_service_bitmap 9778
[*09/01/2019 00:00:09.7999] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*09/01/2019 00:00:09.7999] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*09/01/2019 00:00:09.7999] ol_ath_service_ready_event[4238] WAPI MBSSID 0
[*09/01/2019 00:00:09.8399] wmi_ready_event_rx: WMI UNIFIED READY event
[*09/01/2019 00:00:09.8399] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*09/01/2019 00:00:09.8499] ACS not enabled
[*09/01/2019 00:00:09.8499] ol_ath_thermal_mitigation_attach: --
[*09/01/2019 00:00:09.8499] ol_ath_ahb_probe
[*09/01/2019 00:00:09.8499] ol_ath_ahb_probe: io resource start: 0xa800000, mem=0xc3000000
[*09/01/2019 00:00:09.8499] __ol_ath_attach() Allocated scn 9ecc04c0
[*09/01/2019 00:00:09.8499] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000050
[*09/01/2019 00:00:09.8699]
[*09/01/2019 00:00:09.8699] ol_ath_ahb_configure : num_desired MSI set to 0
[*09/01/2019 00:00:09.8699] Using Legacy Interrupt
[*09/01/2019 00:00:09.8699] Waiting for target init
[*09/01/2019 00:00:09.8699] Done waiting
[*09/01/2019 00:00:09.8699] ol_ath_attach interface_id 1
[*09/01/2019 00:00:09.8699] Chip id: 0xb, chip version: 0x1000000
[*09/01/2019 00:00:09.8699] Target Version is 1000000
[*09/01/2019 00:00:09.8699] Flash Download Address c0000
[*09/01/2019 00:00:09.8699] ol_transfer_bin_file: flash data file defined
[*09/01/2019 00:00:09.8699] ol_transfer_bin_file[3918] Get Caldata for wifi1.
[*09/01/2019 00:00:09.8699] __adf_os_fs_read[42], Open File /tmp/wifi1.caldata SUCCESS!!
[*09/01/2019 00:00:09.8699] file system magic:16914836
[*09/01/2019 00:00:09.8699] super blocksize:4096
[*09/01/2019 00:00:09.8699] inode 3605
[*09/01/2019 00:00:09.8699] file size:12064
[*09/01/2019 00:00:09.8699] qc98xx_verify_checksum: flash checksum passed: 0x5fe5
[*09/01/2019 00:00:09.8799] ol_transfer_bin_file 3979: Download Flash data len 12064
[*09/01/2019 00:00:09.8999]
[*09/01/2019 00:00:09.8999] Board data initialized
[*09/01/2019 00:00:09.8999] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:09.9199] ol_ath_download_firmware :First OTP download and Execute is good address:0x5c00 return param 4660
[*09/01/2019 00:00:09.9199] ol_ath_download_firmware:##Board Id 23 , CHIP Id 0
[*09/01/2019 00:00:09.9199] wifi1: Selecting board data file name boardData_Crete_Outdoor_5G_neg_pwr.bin
[*09/01/2019 00:00:09.9199] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_Crete_Outdoor_5G_neg_pwr.bin
[*09/01/2019 00:00:09.9199] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:09.9399] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:09.9599]
[*09/01/2019 00:00:09.9599] [Flash] : Ignore Module param
[*09/01/2019 00:00:09.9599] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/01/2019 00:00:09.9599] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:09.9699] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
[*09/01/2019 00:00:09.9699] Firmware loaded from user helper succesfully
[*09/01/2019 00:00:10.7899] FWLOG: [105885] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:10.7899] FWLOG: [105885] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:10.7899] FWLOG: [105885] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:10.7899] FWLOG: [105885] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:11.1999] HTC Rx: insufficient length, got:4 expected =8
[*09/01/2019 00:00:11.1999] Startup Mode-0 set
[*09/01/2019 00:00:11.1999] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/01/2019 00:00:11.1999] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/01/2019 00:00:11.1999] Firmware_Build_Number:70
[*09/01/2019 00:00:11.1999] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht_cap_info:0x339959b2 vht_supp_mcs:0x0000fffa
[*09/01/2019 00:00:11.1999] RES CFG Support wmi_service_bitmap 9778
[*09/01/2019 00:00:11.1999] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*09/01/2019 00:00:11.1999] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*09/01/2019 00:00:11.2099] ol_ath_service_ready_event[4238] WAPI MBSSID 0
[*09/01/2019 00:00:11.2499] wmi_ready_event_rx: WMI UNIFIED READY event
[*09/01/2019 00:00:11.2499] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 1
[*09/01/2019 00:00:11.2499] acfg_attach: Offload using existing sock bd9d8000
[*09/01/2019 00:00:11.2599] ACS not enabled
[*09/01/2019 00:00:11.2599] ol_ath_thermal_mitigation_attach: --
[*09/01/2019 00:00:11.3299] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*09/01/2019 00:00:12.1899] FWLOG: [107323] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:12.1899] FWLOG: [107323] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:12.1899] FWLOG: [107323] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:12.1899] FWLOG: [107323] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/01/2019 00:00:12.1899] FWLOG: [107333] UNKNOWN 22:55 ( 0x3a, 0x10, 0x0, 0x10, 0x0 )
[*09/01/2019 00:00:12.4399] pid 3645's current affinity mask: f
[*09/01/2019 00:00:12.4399] pid 3645's new affinity mask: e
[*09/01/2019 00:00:14.3499]
[*09/01/2019 00:00:14.3499] Click sched monitor: schedulers = 3
[*09/01/2019 00:00:15.7999] click-config/io-real.click:131: While configuring 'todev_wired0 :: ToDevice':
[*09/01/2019 00:00:15.7999] warning: device 'wired0' is down
[*09/01/2019 00:00:15.8599] click-config/io-real.click:131: While configuring 'fromdev_wired0 :: FromDevice':
[*09/01/2019 00:00:15.8599] warning: device 'wired0' is down
[*09/01/2019 00:00:16.7599] click-config/io-real.click:131: While initializing 'tohost_wired0 :: ToHost':
[*09/01/2019 00:00:16.7599] warning: device 'wired0' is down
[*09/01/2019 00:00:17.2599] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*09/01/2019 00:00:17.2699] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*09/01/2019 00:00:18.9999] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*09/01/2019 00:[09/01/2019 00:00:19.6099] ess_edma c080000.edma: wired0: GMAC Link is up with phy_speed=1000
00:19.0299] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*09/01/2019 00:00:19.0299] ip6_port srcr6, ip6local fe80::a653:eff:fe6a:6ab8, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[*09/01/2019 00:00:19.7499] IPv6: ADDRCONF(NETDEV_CHANGE): wired0: link becomes ready
[*09/01/2019 00:00:28.4899] Loading sha2...
[*09/01/2019 00:00:28.4999] Dumpping sha1...
[*09/01/2019 00:00:30.2599] Loading MIC cert and key
[*09/01/2019 00:00:30.2599] Dumpping sha2...
[*09/01/2019 00:00:32.0099] Loading MIC cert and key
[*09/01/2019 00:00:32.9199] Generating key, this may take a while...
[*09/01/2019 00:00:37.1899] Public key portion is:
[*09/01/2019 00:00:37.1899] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCuK+GXGqtI8E5pkK1bbFWOP9gYkVjeh5Aveht9VH798mXGoJn8pFyAxDHrtfuh2gIn5L1/zHQy9+VvUSUolJWVXLgJrzgMHzlUlOZIuenEp6nkXKAv17/WWE3JLgMKTDl5YdSym6XWd9qYcuXikZ4TI2mpRWbMnWIopTjUTbOoE0ppPQOmrefh8BabGA56MlamvcMksICQ4oyk1qGJhPkUnyPDuO1RpdqA/Hi3lD+EdgX69J5LMcKncCOWHNRSTIMYhL1Dws98ynzV4EOp0XGVbpQmqvc1O24YJsArXX8vbLkr4TuljdopSu2uQDt03bW+keB6BTWdaQj2umHgt03x root@mA4530E6A6AB8
[*09/01/2019 00:00:37.1899] Fingerprint: sha1!! 08:62:80:d1:55:97:7a:49:51:d3:6d:87:5c:80:f4:21:ed:ed:f7:9d
[*09/01/2019 00:00:42.3999] starting tam services using ACT2...
[*09/01/2019 00:00:42.4199] pid 5462's current affinity mask: f
[*09/01/2019 00:00:42.4199] pid 5462's new affinity mask: e
[*09/01/2019 00:00:42.4399] setting interrupt 200 affinity to 1
[*09/01/2019 00:00:42.4599] setting interrupt 201 affinity to 1
[*09/01/2019 00:00:43.5599] Password for user changed
[*09/01/2019 00:00:43.9899] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/C2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/C5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/12/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP1542I-E-K9/g' -e 's/__AP_TYPE__/75/g' -e 's/__WIRELESS_MAC__/2C:F8:9B:D2:0E:E0/g' -e 's/__WIRED_MAC__/A4:53:0E:6A:6A:B8/g' -e 's/__WIRED1_MAC__/A4:53:0E:6A:6A:B8/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*09/01/2019 00:00:46.8199] CRIT-MeshControl:
[*09/01/2019 00:00:46.8199] Mesh Control: skipped adding wired1 backhaul
[*09/01/2019 00:00:46.8299] DOT11_DRV[1]: Init Radio1
[*09/01/2019 00:00:46.8699] DOT11_DRV[1]: Stop Radio1
[*09/01/2019 00:00:46.8699] DOT11_DRV[1]: set_channel Channel set to 100
[*09/01/2019 00:00:46.8899] DOT11_DRV[0]: Init Radio0
[*09/01/2019 00:00:46.9199] DOT11_DRV[0]: Stop Radio0
[*09/01/2019 00:00:46.9299] DOT11_DRV[0]: set_channel Channel set to 6
[*09/01/2019 00:00:47.0799] DOT11_CFG[0] Radio Mode is changed from Local to FlexConnect
[*09/01/2019 00:00:47.0799] DOT11_DRV[0]: Start Radio0
[*09/01/2019 00:00:47.0799] DOT11_CFG[1] Radio Mode is changed from Local to FlexConnect
[*09/01/2019 00:00:47.0899] DOT11_DRV[1]: Start Radio1
[*09/01/2019 00:00:47.0999] DOT11_DRV[0]: Stop Radio0
[*09/01/2019 00:00:47.3099] DOT11_DRV[0]: set_channel Channel set to 1
[*09/01/2019 00:00:47.3199] DOT11_DRV[0]: Start Radio0
[*09/01/2019 00:00:47.3199] DOT11_DRV[0]: Channel set to 1, width 20
[*09/01/2019 00:00:47.3199] DOT11_DRV[0]: Stop Radio0
[*09/01/2019 00:00:47.5399] DOT11_DRV[0]: Channel set to 1, width 20
[*09/01/2019 00:00:47.5399] DOT11_DRV[1]: Stop Radio1
[*09/01/2019 00:00:47.5599] DOT11_DRV[1]: set_channel Channel set to 100
[*09/01/2019 00:00:47.5699] DOT11_DRV[1]: Start Radio1
[*09/01/2019 00:00:47.5699] DOT11_DRV[1]: Stop Radio1
[*09/01/2019 00:00:47.7999] DOT11_DRV[1]: Start Radio1
[*09/01/2019 00:00:47.7999] DOT11_DRV[1]: Channel set to 100, width 20
[*09/01/2019 00:00:47.7999] DOT11_DRV[1]: Stop Radio1
[*09/01/2019 00:00:47.8099] DOT11_DRV[1]: Channel set to 100, width 20
[*09/01/2019 00:00:47.8099] Failed to load flex AP config from file. Default config will be used.
[*09/01/2019 00:00:51.8599] Waiting for uplink IPv4 configuration
[*09/01/2019 00:00:56.8699] Waiting for uplink IPv4 configuration
[*09/01/2019 00:01:01.8699] Waiting for uplink IPv4 configuration
[*09/01/2019 00:01:02.2599] ethernet_port wired0, ip 192.168.113.48, netmask 255.255.255.0, gw 192.168.113.1, mtu 1500, bcast 192.168.113.255, dns1 0.0.0.0, domain AUF.com, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*09/01/2019 00:01:12.9899] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*09/01/2019 00:01:12.9899] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*09/01/2019 00:01:13.0599] AP IPv4 Address updated from 0.0.0.0 to 192.168.113.48
[*09/01/2019 00:01:32.5599]
[*09/01/2019 00:01:32.5599] !!!!! {/usr/bin/capwap_brain} failed writing /click/fromdevs_check_gw/color len 1 data: "0"
[*09/01/2019 00:01:32.5599] ethernet_port wired0, ip 192.168.1.2, netmask 255.255.255.255, gw 192.168.1.2, mtu 1500, bcast 192.168.1.255, dns1 0.0.0.0, domain AUF.com, vid 0, static_ip_failover true, dhcp_vlan_failover false
[*09/01/2019 00:01:32.7399] chatter: tohost_virtual :: ToHost: device 'virtual' went down
[*09/01/2019 00:01:32.7899] chatter: tohost_vlan0 :: ToHost: device 'vlan0' went down
[*09/01/2019 00:01:32.8299] chatter: tohost_vlan1 :: ToHost: device 'vlan1' went down
[*09/01/2019 00:01:32.8799] chatter: tohost_vlan2 :: ToHost: device 'vlan2' went down
[*09/01/2019 00:01:32.9499] chatter: tohost_vlan3 :: ToHost: device 'vlan3' went down
[*09/01/2019 00:01:33.0099] chatter: tohost_vlan4 :: ToHost: device 'vlan4' went down
[*09/01/2019 00:01:33.0699] chatter: tohost_vlan5 :: ToHost: device 'vlan5' went down
[*09/01/2019 00:01:33.1099] chatter: tohost_vlan6 :: ToHost: device 'vlan6' went down
[*09/01/2019 00:01:33.1599] chatter: tohost_vlan7 :: ToHost: device 'vlan7' went down
[*09/01/2019 00:01:33.1999] chatter: tohost_vlan8 :: ToHost: device 'vlan8' went down
[*09/01/2019 00:01:33.2399] chatter: tohost_vlan9 :: ToHost: device 'vlan9' went down
[*09/01/2019 00:01:33.3199] chatter: tohost_vlan10 :: ToHost: device 'vlan10' went down
[*09/01/2019
Cryptographic library self-test....
Testing SHA1 Short Message 1
Testing SHA256 Short Message 1
Testing SHA384 Short Message 1
SHA1 POST PASSED
Testing HMAC SHA1 Short Message 1
Testing HMAC SHA2 Short Message 1
Testing HMAC SHA384 Short Message 1
passed!
XML config selected
/bin/sh: /usr/bin/iptables: not found
Starting SSHD: Generating Secure Shell DSA Host Key ...
Generating Secure Shell RSA Host Key ...
Generating Secure Shell version 2 ECDSA Host Key ...
ok
Validating XML configuration
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 8.5.140.0
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Network Services: ok
Starting Statistics Service: ok
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Network Interface Management Services: ok
Starting System Services:
As the Mgmt Address is updated, all the DHCP scopes with Central NAT enabled will be disabled and enabled
As the Mgmt Address is updated, all the WLANs associated with central NAT enabled scopes will be enabled and disabled
ok
Starting SNMP services: ok
Starting Fastpath Hardware Acceleration: Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces:
ok
Starting Client Troubleshooting Service: ok
Starting Certificate Database: Initializing Curl Globally..
ok
Starting VPN Services: ok
Starting Management Frame Protection: ok
Starting DNS Services: ok
ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting LOCP: ok
Starting Security Services: ok
Starting Authentication Engine: ok
Starting Capwap Ping Component: ok
Starting AVC Services: ok
Starting AVC Flex Services: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting RF Profiles: ok
Starting Mesh Services: ok
Starting TSM: ok
Starting CIDS Services: ok
Starting Ethernet-over-IP: ok
Starting DTLS server: enabled in CAPWAP
Starting CleanAir: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting RRC Services: ok
Starting SXP Services: ok
Starting Alarm Services: ok
Starting FMC HS: ok
Starting FLEXEXPRESS ConfigSync Task: ok
Starting HTTP Image Download Task: ok
Starting Tunnel Services New: ok
Starting Portal Server Services: ok
Starting Management Services:
Web Server: CLI: Secure Web: ok
Starting IPSec Profiles component: ok
Starting CPU ACL Logging services: ok
Enabling Controller Provisioninggrep: /mnt/application/xml/clis/clifile: No such file or directory
sh: can't create /mnt/application/xml/clis/clifile: nonexistent directory
Configuring management interface
Enabling mgmt via wireless
Enabling Provisioning SSID
SSID: CiscoAirProvision, Admin Status: 1, Interface Name: management, 802.11 Auth: WPA2-PSK, Wi-Fi Protected Access : Enabled
(Cisco Controller)
Cisco Aironet 1542 Series Mobility Express
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
Would you like to terminate autoinstall? [yes]:
Leo Laohoo
Console into the AP and boot the AP.
Post the entire boot-up process.
Thanks for replay
DRAM: 1022 MiB
MFG data loaded
Total valid parts=4
machid: 8010001
AR8033 PHY 0
PHY ID1: 0x4d
PHY ID2: 0xd072
Booting from part2
Signature returns 0
bootm 0x88000400
Starting image ...
Welcome to Cisco.
available at:
Cisco Systems, Inc.
export@cisco.com.
[*09/01/2019
SHA1 POST PASSED
passed!
XML config selected
ok
ok
ok
ok
ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting LOCP: ok
Starting TSM: ok
Starting WIPS: ok
Starting FMC HS: ok
(Cisco Controller)
If you look at the end of the output, your ap is Mobility Express. You need to convert the AP from ME to capwap. You can search up on the web, but here is one link that you can review. https://wrmem.net/index.php/2018/04/03/converting-a-mobility-express-ap-into-a-capwap-ap/
-Scott
djawedn74329
Hello , I have the problem that the AP is not forwarded in the WLC.
Created the vendor class, but I'm not sure if it's correct.
how do you generate the vendor class?
Or is there a list or source for it?
Please find the below document
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
if your AP’s and WLC AP Manager interface is in the same broadcast domain you don’t have to use dhcp options.
Unfortunately that is not possible. the ap, s of 190 clinics are administered in this wlc.what are the hexadecimal values ​​for the ap?
Option 43 should contain ip address of the AP manager interface of ur WLC. Just convert it to Hex, you can find many converters online.
