WLC 4400 and Integration with ACS
AJAZ NAWAZ
Level 5
Level 5
We have single WLC, the deployment is simple. One corporate user wlan, one guest wireless vlan and one corporate wlan. Currently we are only using guest wired/wireless LAN.
Now we're looking to integrate ACS with some form of automated authentication such as RSA. The RSA infrastructure is already in place. The laptops are using standard wireless lan client. So this is where I want to get to - the qtn is how to get there?
i know this is going to require a lot of reading
dancampb
Level 7
Level 7
Have you looked at this doc?  Its a configuration example of setting up a controller to authenticates against ACS with a RSA backend.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a008090399a.shtml
nice doc. is there also something available for the config required on the WLC to make this work..?
bingo on the way!
