08-17-2010 01:48 PM - edited 07-03-2021 07:05 PM
We have a WLC 4402 running 7.0.98.0 with several 1131s, 1300s, and 1 1231. Since i upgraded from 6 ro 7.0.98.0 the SSIDs aren't broadcasting on the 1231. I have an AP Group with two WLANS and the AP joined to it but the SSIDs aren't broadcasting. Any suggestions?
08-17-2010 02:49 PM
What switch is the 1230 connected to? How is it powered, PoE, Injector or power brick/adaptor?
08-18-2010 05:16 AM
2960 and external power. the AP is joined and talking to the WLC just not broadcasting the 2 configured SSIDs in the AP Group. This only happened after the upgrade.
08-23-2010 01:01 PM
sorry to bump...any suggestions?
08-23-2010 04:34 PM
Dunno. Never seen this before. If you take the APs out of the AP Group what happens? Maybe all you need to do is to "rip" out the AP Groups and create them again.
08-23-2010 04:45 PM
I assume your clients are still connecting? Have you set the correct WLAN-id?
Also, from what I recall the default group, handles up to 16 broadcasts SSID.
What happens if you enter: config network broadcast enable ?
09-09-2010 11:09 AM
Hello Al I was able to reply this issue, I have the next scenario:
1 WLC 4402 fw ver 7.0.98.0 for 50 ap's that are managing just 23 aironet 1242, 22 of the 23 ap's are connected to a Catalyst 3560 however the ap' that is alone is connected by a power injector to another sw vendor. This ap is not able to enable the interface dot11 0 corresponding to the 802.11 b/g radio event when i configured the ap to support a power injector with the mac address of the switch port that is connected.
I think it could be a firmware issue if it worked with the older fimrware version of the wlc
Did it work properly with the older firmware version?
09-09-2010 11:13 AM
i forgot to add al the Catalyst switches have POE
