WLC 4402 - Can't ping between devices
voipis4me
I have a laptop connected to SSID1 and another to SSID2. Each can ping each other without a problem, but neither can ping a device on the SSID3 network. From a hard line (in this case off of one of the servers) I can ping the device on the SSID3 network without a problem.
There are no ACLs applied on the WLC or core switch where the VLANs are implemented.
Is there a setting somewhere on the SSID3 interface that could be blocking traffic?
We are running code 6.0.188.  All APs are 1242AG.
Thanks in advance for your help.
dancampb
Level 7
Level 7
Do you have P2P Blocking enabled on the WLAN?  Or maybe an ACL on the default gateway between the two VLANs?
P2P blocking is disabled.
Turns out that the issue is with the clients and not the network.
