my guest ssid is set to L2 security none and L3 Web policy and authentication local. clients that need to connect to some vpn server (internet) are reporting disconnection issues with the vpn session but not the wireless network. as soon as they get connected via another wireless internet connection the vpn connection gets stable. that makes me thing is in deed the my wireless network the one causing issues. is there a know issues with the web authentication WLAN and vpn clients? no firewall in the middle.
Exclusionlist.................................... Disabled
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ xxxxxxxxxxxxxxxx
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
--More or (q)uit current module or <ctrl-z> to abort
Quality of Service............................... Bronze (background)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Disabled
Accounting.................................... Disabled
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Enabled
ACL............................................. Unconfigured
Web Authentication server precedence:
1............................................... local
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
H-REAP Local Switching........................ Disabled
H-REAP Learn IP Address....................... Enabled
Client MFP.................................... Optional but inactive (WPA2 not configured)
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
