WLC 5508 and AIR-LAP1042N
Aleksei.Zjabkin
Hi everyone!
Question is simple, but I cannot find it in google.
Does WLC 5508 support AIR-LAP1042N?
Reagrds,
Aleksei
8 Replies 8
Scott Fella
Yes it is supported on the 5508. It depends on the code version and if he wlc supports that code. See the link.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_116_0.html#wp610751
-Scott
Thank You,
In other words I need Cisco Unified Wireless Controller SW Release 7.0 for WLC 5508 to make these two things operate with each other.
You are correct.
-Scott
One more question.
What poe injector is supported on AIR-LAP1042N?
I have found poe injectors for other APs.
1.AIR-PWR-B=
2.AIR-PWRINJ4
Will anyone of these support this AP?
Either one will work:
Powering Options
• 802.3af Ethernet Switch
• Cisco AP1040 Power Injectors (AIR-PWRINJ4=)
• Cisco AP1040 Local Power Supply (AIR-PWR-B=)
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps11203/data_sheet_c78-609338.html
-Scott
Big Thanks
should work with the PWRIINJ4 for the injector. The PWR-B for hard power
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Yes, the 5508 supports the 1042, so long as the code you are running supports them, which starts with 7.0.98.0
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_116_0.html#wp767176
HTH,
Steve
HTH,
Steve
